scpal9
Jun 18, 2022Aspirant
Netgear r6400
Why can I not get speeds of 400 mbps? I can get it hardwired to modem. When I try through netgear router I can only get 200 mbps. Tried a reset after version update. Still only 200 mbps. Help would be...
scpal9
Jun 19, 2022Aspirant
The modem is from spectrum. I have tested it using my Xbox series one. Directly from the modem and then hardwired from router. The speeds drop from the router. I only said the wifi speeds, because the other person wanted to know the model. Thus I kinda gave it has part has the description.
michaelkenward
Jun 19, 2022Guru - Experienced User
We still don't know what it is.
My guess is that Spectrum has provided a pile of different modems over the years.
This could be crucial information.
- scpal9Jun 19, 2022AspirantI don't really know what brand it is. It just says spectrum on it. It was exchanged. Before this one I had an Arris modem from spectrum. This has happened with both modems. I think it has to do something with the router itself. Don't know if a old firmware update affected it or a setting. I don't know off a setting that would throttle how fast data runs through a port.
- michaelkenwardJun 20, 2022Guru - Experienced User
scpal9 wrote:
I don't really know what brand it is. It just says spectrum on it.No label on the back?
I don't know off a setting that would throttle how fast data runs through a port.Some ISPs supply modem/routers. These can get in the way when you add another router to the chain.
It isn't usually fatal, but it hinders troubleshooting.
What is Double NAT? | Answer | NETGEAR Support
- plemansJun 20, 2022Guru - Experienced User
Did you ever try a factory reset?
If not, do a factory reset.
During the reinstall, make sure to leave qos, access control, traffic monitoring, and parental controls all disabled.
reason why is those services disable cut through forwarding (ctf). Ctf is needed for those older/base model devices to hit gigabit speeds. When ctf is disabled, the processor has to do traffic inspection and it doesn't have the cpu to manage much past that 200mbps.
Usually you can just disable those services and ctf gets re-enabled. But i have seen instances where it doesn't and a full factory reset is needed to re-enable it.
- scpal9Jun 20, 2022AspirantThanks. Did a factory reset a bunch of times before making this post. No luck.
- plemansJun 21, 2022Guru - Experienced User
Did you do a fresh install? By fresh I mean making sure not to use a backup configuration. Test if with everything in the default settings and see what speeds you get. If you get full speeds, then start customizing/testing and see at what point it drops the speeds
