scpal9
Jun 18, 2022Aspirant
Netgear r6400
Why can I not get speeds of 400 mbps? I can get it hardwired to modem. When I try through netgear router I can only get 200 mbps. Tried a reset after version update. Still only 200 mbps. Help would be...
scpal9
Jun 20, 2022Aspirant
Thanks. Did a factory reset a bunch of times before making this post. No luck.
Jun 21, 2022Guru - Experienced User
Did you do a fresh install? By fresh I mean making sure not to use a backup configuration. Test if with everything in the default settings and see what speeds you get. If you get full speeds, then start customizing/testing and see at what point it drops the speeds
