TidO8's avatar
TidO8
Netgear R6400v2 - unable to play content from HDD (USB 3.0) on Samsung TV
Hello, I have connected Samsung 2,5" HDD to Netgear R6400v2 and created a network folder. Everything works OK from any PC in the network. But when I try to play anything from the HDD on Samsung TV (...
  • TidO8's avatar
    TidO8
    Feb 16, 2020
    I made few tests to find out what is causing the problem and this is my opinion.
    If I delete file in \\readyshare\.ReadyDLNA\files.db and let router to create it, the error "Check network connection" pop ups for all media files.
    If I let PLEX to create the file, everything works OK (few formats are not supported, but that is normal I think).
    If anything changes on HDD, router is able to update the file and new media files can be played without any problems.
    And also ARMOR cannot be included in firmware. If it is included in firmware it doesn't matter if it is enabled or not, streaming anything is not possible with the same error "Check network connection".
    Thank you so much for your help :-) I really appreciate that.
