Dixielovesme
Feb 04, 2023Aspirant
Netgear R6400V2 keeps locking up
I have an R6400V2 WifI router with firmware V1.0.4.128_10.0.104. The latest as I set up to auto update. There are about 18 attached devices with 7 being Ring Cameras. Seems like every day, the rou...
microchip8
Feb 04, 2023Master
- WMM increases throughput, so turn it on. WMM is not "regular" QoS.
- Have you done a factory reset and reconfigure from scratch?
- Turn off automatic firmware updates. It can silently brick your router.
Dixielovesme
Thank you. I will re-instate WMM and go back to factory defaults.
(Tomorrow after church, because we still need it to stream).
I do have the Ethernet port that connects to the streaming device as a high priority. It is hard-wired for better throughout and stability.
