Dixielovesme
Feb 04, 2023Aspirant
Netgear R6400V2 keeps locking up
I have an R6400V2 WifI router with firmware V1.0.4.128_10.0.104. The latest as I set up to auto update. There are about 18 attached devices with 7 being Ring Cameras. Seems like every day, the rou...
michaelkenward
Feb 05, 2023Guru - Experienced User
Dixielovesme wrote:
Seems like every day, the router stops communicating, and I can't log into it.
The wireless signals on front panel show good and the internet signal shows good.
Those symptoms raise an immediate question, what delivers the Internet to the router?
Make and model of the modem/gateway/Optical Network Terminator (ONT) in front of it.
Dixielovesme
Feb 05, 2023Aspirant
After the router locked up again today, I just said to heck with it and replaced with a newer version - the AC 1800, called RAX10. The wifi has better range and everything is stable. Just didn't want to do factory resets and other trouble shooting on an older generation product.
Case closed.
