Bzq
May 29, 2022Aspirant
Netgear R6400v2
I want to update/review the time zone in the R6400v2 router. From a web research, I go to Advance/Security/Schedule. I have no other options after these steps. How do I review the time zone? I was ...
- May 31, 2022
Bzq wrote:
I want to update/review the time zone in the R6400v2 router. From a web research, I go to Advance/Security/Schedule. I have no other options after these steps. How do I review the time zone? I was originally in Eastern time zone and now reside in Central.
Netgear has been moving things around with new firmware.
If it is your local time that you want to synchronise, you need to find the NTP settings. Maybe they moved them on your device.
Poke around in Advanced > Administration >
Look for NTP Settings.
Sadly, but perhaps not surprisingly given the state of Netgear's manuals, the ,manual for the R6400v2 is silent on this issue.
michaelkenward
May 31, 2022Guru - Experienced User
- BzqJun 06, 2022Aspirant
Thank you Michael. Your response was spot on. Thank you so much again.
- michaelkenwardJun 06, 2022Guru - Experienced User
Thanks for confirming my suspicions/guesswork.
Now we know where to look for those settings.
