shannonehlers18
Oct 08, 2020Aspirant
Netgear range exstender ex6150v2
Won't connect to wifi
- Oct 08, 2020
going to need a little more info.
1. What router are you connecting it to?
2. firmware on the extender?
3. how are you setting it up? using wps or the installation wizard?
4. Where is it failing in the process. There's many steps and we're not there to see what you're doing, where its failing, the errors, etc. we need more info than "it won't connect". help us to help you.
Oct 08, 2020Guru - Experienced User
- shannonehlers18Oct 09, 2020AspirantI was connecting to our local water treatment plants open wifi we live a few miles out of town so I don't have physical access to the router... so when Netgear set it up remotely view my computer about a year ago they somehow hooked up to the router and they were unable to connect to the Wi-Fi so since then family has been on my pc and wifi and now the router light forest come on ...all lightswork when u plug it in.......netgear only told me that it was cause of all the traffic is why it won't connect it would have to be cleaned out.
- shannonehlers18Oct 09, 2020AspirantSorry I meant they were able to connect
- shannonehlers18Oct 09, 2020AspirantAnd yes it has firmware on it but not updated ....i would update but can't with no wifi and another thing don't know if this means anything but the clock on the exstender is always the same when I try to rest factory setting March 3 2018 it says last time password was changed was in March but I know that's not true cause I've changed it a million times since then .....ps exstender was bought at a garage sale
- plemansOct 13, 2020Guru - Experienced User
You are able to update without wifi. You download the file from the support site, extract it, and then follow the manual firmware update process.
https://www.netgear.com/support/product/EX6150v2.aspx
does the "open wifi" have a login/terms and conditions you have to agree to?
- shannonehlers18Oct 14, 2020AspirantNo it does not have any terms or condition and I can't update the firmware
