shannonehlers18
Oct 08, 2020Aspirant
Netgear range exstender ex6150v2
Won't connect to wifi
- Oct 08, 2020
going to need a little more info.
1. What router are you connecting it to?
2. firmware on the extender?
3. how are you setting it up? using wps or the installation wizard?
4. Where is it failing in the process. There's many steps and we're not there to see what you're doing, where its failing, the errors, etc. we need more info than "it won't connect". help us to help you.
Oct 08, 2020Guru - Experienced User
shannonehlers18
Oct 09, 2020Aspirant
Sorry I meant they were able to connect
