DLJMCGEE
Jan 01, 2023Aspirant
NETGEAR ROUTER 150 WNR1000
My router has a blinking blue light....should I been conerned.??? Can I turn off the blinking light?
michaelkenward
Jan 01, 2023Guru - Experienced User
Do you have any problems with the router?
Did you check the manual for what the LEDs mean?
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Troubleshoot With the LEDs.
I'd be more concerned that my 14 year old router might not be good enough to meet my current needs.
No 5 GHz wifi, LAN connections limited to 100 Mbps, possibly slower than your Internet service.
