Sep 10, 2021Follower
Netgear Router C6220
I couldn't get my wifi to work on my phone, it keeps happening through xfinity. This time when I talked to someone and they had me push the reset button on the router for 30 seconds. It showed I was c...
Sep 10, 2021Guru - Experienced User
After you reset it, did you reinstall it using the guide?
https://www.netgear.com/support/product/C6220.aspx
