Sep 10, 2021Follower
Netgear Router C6220
I couldn't get my wifi to work on my phone, it keeps happening through xfinity. This time when I talked to someone and they had me push the reset button on the router for 30 seconds. It showed I was c...
michaelkenward
Sep 11, 2021Guru - Experienced User
0603 wrote:
I couldn't get my wifi to work on my phone, it keeps happening through xfinity. This time when I talked to someone and they had me push the reset button on the router for 30 seconds. It showed I was connected on my phone, but I can't get to any website using my wifi. I am using my phone's data right now to try to figure out what to do. Please help
Is it the phone that is bust or the modem/router?
It isn't obvious from this that the wifi is working in your C6220.
Can you connect other things to the wifi from the C6220? Can your phone connect to other wifi sources?
