shaipatel
Jun 04, 2021Follower
Netgear router compatible with Frontier Fios
Hello I have actually a RAX70. I am trying to replace a Frontier Fios modem/router. I have hooked this netgear up and I can not seam to get wired internet service. All lights are white. Than...
michaelkenward
Jun 05, 2021Guru - Experienced User
shaipatel wrote:
....I can not seam to get wired internet service. All lights are white.
What does that mean?
What doesn't get wired Internet access?
Do you get wifi Internet access on anything? If so, the problem is probably not with the router.
You have posted your message in the section of this community given over to General WiFi Routers (Non-Nighthawk). (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
