GarryCR
Aug 15, 2020Follower
Netgear Router D6220 Firmware update issue
hi, I have followed Netgear instuctions to update D6220 router to latest firmware, connected to router via wifi and using Genie, downloads 1.0.0.60 ok, then router reboots ( connection reset mesage a...
- Aug 16, 2020
You should update your router while its connected via ethernet cable. Download the firmware file to your computer and then update it manually. I wouldn't ugrade the firmware to any router wirelessly since you risk bricking it if it disconnects from the wifi at some point.
michaelkenward
Aug 16, 2020Guru - Experienced User
Which instructions? Manual or automated?
Manual is more reliable
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
DSL Modems & Routers
