mohdshoeb67
Mar 10, 2017Aspirant
Netgear router is redirecting back to routerlogin page
Hello Guys, I got stuck with a serious issue. My router is redirecting many of the addresses to the routerlogin page and in some of the cases i am getting connection refused error. Actually my c...
- Mar 18, 2017
Thanks all for your help,
there was a hardware issue in the router and it got fixed in service center.
ElaineM
Mar 10, 2017NETGEAR Employee Retired
Welcome to the community, mohdshoeb67
Try the following link below on how to disable it.
How to disable NETGEAR configuration assistant (welcome screen / hijack screen)?
mohdshoeb67
Mar 11, 2017Aspirant
Hello ElaineM
Thanks for your quick response.
I followed the exact steps mentioned on this post on Internet Explorer after connecting my system with Ethernet cable to the router, but when i tried to access www.routerlogin.com/CA_HiddenPage.htm it's not showing me anything. only a blank page is appearing here.
I rebooted router as well as my system several times and also tried to access 192.168.1.1/CA_HiddenPage.htm but no luck.
I am using Netgear N150-JNR1010V2 wireless router and firmware version is V1.1.0.32_1.0.1
Thanks,
Shoeb
- William10aMar 12, 2017Master
mohdshoeb67 wrote:Hello ElaineM
Thanks,
Shoeb
Try using just use 192.168.1.1 when asked enter user name and password.
- mohdshoeb67Mar 12, 2017Aspirant
Hi,
I already tried and it is working fine, but that's not my problem. my routerlogin page is working fine.
My actual problem is,, I am getting reouterlogin page whenever i am trying to open any page for example let's say I want to open www.youtube.com so when i put this address in browser's URL bar it is opening routerlogin page instead of youtube. I tried flushing DNS cache of my system and tried with differrent systems but i am getting same behavior.
So it is not the your's and any of the other computers you tried problem the router returns you to a login page when you try and access any web site.
Have you rebooted the network to clear left over data from when last logged into the router?
The router has to stick in login mode some how the orther computers you tried would not know about your loging into router this may clear it.
Did you update the firmware to the before this happen?
