allwowth
Mar 05, 2017Aspirant
Netgear router not accepting correct primary and secondary DNS settings
I'm trying to setup OpenDNS.. When I put in the OpenDNS primary (202.67.222.222) and secondary (208.67.220.220) settings and click "Apply" the settings shown are different. Primary: 195.67.222.222 ...
- Mar 08, 2017
Elaine:
I did the 30-30-30 reset. Still the same problem. I'll purchase a new router, Netgear, of course.
Many many thanks for all the help.
Gus
ElaineM
Mar 06, 2017NETGEAR Employee Retired
Welcome to the community, allwowth
What's the exact model number of the NETGEAR device?
Did you enable OpenDNS feature or you're simply using the OpenDNS addresses?
allwowth
Mar 06, 2017Aspirant
Elaine:
Thanks for the post.
The model number is WNDR3700 V2, (N600). I appreciate any advice you can give me.
Gus
- ElaineMMar 06, 2017NETGEAR Employee Retired
What's the firmware installed on the router?
Do you have the latest firmware installed?
If not, update the firmware or re-upload it then factory reset the router.
