allwowth
Mar 05, 2017Aspirant
Netgear router not accepting correct primary and secondary DNS settings
I'm trying to setup OpenDNS.. When I put in the OpenDNS primary (202.67.222.222) and secondary (208.67.220.220) settings and click "Apply" the settings shown are different. Primary: 195.67.222.222 ...
- Mar 08, 2017
Elaine:
I did the 30-30-30 reset. Still the same problem. I'll purchase a new router, Netgear, of course.
Many many thanks for all the help.
Gus
allwowth
Mar 06, 2017Aspirant
Elaine:
Thanks for the post.
The model number is WNDR3700 V2, (N600). I appreciate any advice you can give me.
Gus
ElaineM
Mar 06, 2017NETGEAR Employee Retired
What's the firmware installed on the router?
Do you have the latest firmware installed?
If not, update the firmware or re-upload it then factory reset the router.
- allwowthMar 06, 2017Aspirant
Elaine:
I believe I do, I check for updates monthly and it says no new firmware available.
Version on there is 1.0.1.14.
Thanks.
Gus
- ElaineMMar 06, 2017NETGEAR Employee Retired
Did you try to re-upload the firmware?
You are assigning it under the LAN IP, correct?
Elaine:
Under "Internet IP Address" I have it set to "Get dynamically from ISP". For Domain Server (DNS) Address" i have this set to "Use these DNS servers" which is where I try to put the Open DNS primaryt and secondary addresses in.
Thanks. Gus
