Shafqat
May 10, 2023Aspirant
Netgear Router R6260 - doesnt keep my settings
Hi, I purchased the Netgear router on ebay. Reset everything, but when I try to login to adjust settings, it does not keep my changes i.e. password or secret questions. I have tried factory reset bu...
Shafqat
Factory reset.
Added all the information to setup the router along with Admin password changes and security questions. When it was all setup, I tried to connect on my laptop using 192.168.1.1, it didnt accept the Admin details, asked for Router Serial number and then security questions which all failed.
May 10, 2023Guru - Experienced User
I've seen it where if you don't put in the proper requirements for the password, it makes you go back through password recovery/setup.
Make sure to have 10 chacters
1 special
1 number
1 upper case letter
1 lower case letter.
