Shafqat
May 10, 2023Aspirant
Netgear Router R6260 - doesnt keep my settings
Hi, I purchased the Netgear router on ebay. Reset everything, but when I try to login to adjust settings, it does not keep my changes i.e. password or secret questions. I have tried factory reset bu...
Shafqat
Factory reset.
Added all the information to setup the router along with Admin password changes and security questions. When it was all setup, I tried to connect on my laptop using 192.168.1.1, it didnt accept the Admin details, asked for Router Serial number and then security questions which all failed.
michaelkenward
May 10, 2023Guru - Experienced User
Is it connected to a modem of some sort?
- ShafqatMay 10, 2023Aspirant
Its connected to a Virgin Media router, I use it as an access point but also a ethernet connection. Both the Wifi and Ethernet drop out and then comes back on again, happens every few hours. So I reset everything and wanted to see if there are some settings in the Netgear router that I need to change.
- michaelkenwardMay 10, 2023Guru - Experienced User
Pity you didn't say that at the outset.
You said earlier:
When it was all setup, I tried to connect on my laptop using 192.168.1.1, it didnt accept the Admin details, asked for Router Serial number and then security questions which all failed.If the R6260 is set up in AP mode, then you can forget about using that way into the R6260.
You need to get the IP address from the attached devices list in your main router. Then feed that into a browser to get at the AP's controls.
Ok great. I will try that. Thanks.
