TechTurtle
Aug 16, 2021Aspirant
Netgear Router WiFi light: should it be solid or blinking?
Hi there! I have a Netgear R6220 router and I am wondering if my wifi symbol light is supposed to be a solid green light? (The symbol is the one that looks like a dot with two brackets on each side -...
TechTurtle
Know how to get rid of the blinking so it turns solid? I’ve been spending all day trying to figure this out!
Aug 16, 2021Guru - Experienced User
Shut off all your wifi devices?
Its designed to blink to show that devices are connected and transmitting data over wifi.
