Truckload
Jun 20, 2022Follower
Netgear router
I hooked up Netgear router to Verizon modem and wasn’t able to get online. So ran Ethernet cable from computer tower to router and now it works. Is this correct?
Jun 20, 2022Guru - Experienced User
Verizon doesn't tend to use just modems. they tend to use modem/router combo devices.
And it causes a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
