shumphr1
Jul 12, 2022Aspirant
Netgear RP614v2 to be used as an access point / extender to Vodafone Pro Wifi router - Help required
Hi All, I have a Vodafone provided router with 4 ethernet ports on the back which is up and running fine. The wifi boosters are not really reliable enough so I am resorting to feeding cables from t...
michaelkenward
Jul 13, 2022Guru - Experienced User
shumphr1 wrote:
The wifi boosters are not really reliable enough so I am resorting to feeding cables from the 4 ports throughout the house.
If you want to get wired Ethernet around the place, investigate Powerline Ethernet. It uses the mains circuit as a substitute for Ethernet cables. Great for connecting things like smart TVs that don't move around the place.
shumphr1
Jul 13, 2022Aspirant
Many thanks yes, I have one to provide internet to the shed, 20m down the garden but the house has lots of old fuse boxes that should be in a museum and so plugging in doesn't cover the whole house, just one set of sockets or another., house need rewiring really!
