DMan23
Sep 17, 2025Follower
Netgear Suggested Upgrade Due To EOL Support
Just received a notification email from Netgear re: the end of life / support on my working, old R6700 Nighthawk AC1750. Continues to work fine for our home size, broadband speed, and devices. Home s...
JWS9518
Sep 19, 2025Luminary
I would agree with the others, if it is working fine for you, then I would not worry about it yet.
One thing that I will add though, that I noticed when my R7000 that I use to have started getting long in the tooth, is that the more devices you have, the more problems that router started having. If you start getting newer devices or adding more, you may notice that the router can't handle it and starts to have issues and drops. When I got around 30 to 35 networked devices, I started noticing issues, which then forced me to upgrade to a newer device.
