catadiel
Oct 10, 2016Initiate
Netgear USB control center MacOS Sierra
How about support status for Sierra? Another project online wich offer similar functionality and suffered the same issues claims that on Sierra's next update (10.12.1 now in beta) Apple has restored...
- Mar 16, 2017
We have officially released the compatible software to work with Mac OSX and above.
Wfl
Dec 22, 2016Aspirant
I contacted support and they want me to buy extended warranty. I do not wish to do this since I think this is not a warranty problem but a Netgear problem. They told me to do it myself!!!! I'm not very happy with that answer and looked at the support and still see the same downloads. This is not helping in any way shape or form. Is the download I just did for security that Netgear came out with help??? Any answer at all would be something. Thanks
catadiel
Dec 31, 2016Initiate
I've the same problem: warranty expired so I can't get into netgear support to request the beta.
Could I have access to the beta testing?
regards
Carlo
- ElaineMJan 03, 2017NETGEAR Employee Retired
catadiel Support should still provide you the beta even if you're out of warranty.
For tracking purposes, you need to get a case number logged for that. You may tell support that it's a known issue about the USB Control Center Utility or better yet submit an online case.
- Tsteele23Jan 27, 2017Guide
any ideas when this newer version of USB Control Center will be GA? I'm in the same boat too, after upgrading my Mac, found out that the only application that no longer works is this Netgear application, and I can no longer print. I can't log a new case, as my account no longer provides an option to submit a new case. Am I able to get a download copy of the beta version please?
Thanks
Tim
- jiashun_zhangMar 09, 2017Aspirant
My router is out of date, How can I get the beta software?
- ElaineMMar 16, 2017NETGEAR Employee Retired
