JLEVAVASSEUR
Sep 13, 2015Tutor
NETGEAR USB Control Center utility for MAC OS X El Capitan
NETGEAR USB Control Center utility v 2.22 is not compatible with MAC OS X El Capitan, where to download or make NETGEAR USB Control Center utility with the new MAC OS X ?
- Mar 16, 2017
Hello All,
You may now download the official release of the USB Control Center Utility for MAC OS 10.11 and above from the link below.
LostPetrel
Dec 04, 2015Apprentice
I think the suggestions and links that Elaine has provided have been helpful even if not being my solution. I see no reason to stop this discussion, no one is being forced to follow it.
daraghfi
Dec 05, 2015Aspirant
With all due respect, I joined this thread to get an update for when the "NETGEAR USB Control Center utility for MAC OS X El Capitan" will be fixed - that is why I subscribed to the thread and get an email with every update. Anything else is actually and literally off-topic, and therefore noise.
I say this not to be rude, but to ask you to think about the context of your conversation, and the topic at hand. By all means create a new topic for your discussion of altenative methods of printing from a Mac. I am just saying that that discussion is not for this thread. Others can follow you to the other thread, but I cannot change the topic of this thread for you to continue here.
The other reality of the off-topic interchange is that every time we get an email without a resolution to the topic at hand, it just confirms that Netgear is not a vendor I want to work with, either with the ability to deliver quality and well supported product, or to publish well-developed interim solutions. "Booo", I say.
Thank you for your consideration.
D
- jmanthonyDec 05, 2015Apprentice
D,
If you don't like Netgear, then maybe you should just return the router and get a different brand that works. I'm sure you can find something out there that's a suitable solution.
For those of us who are toughing it out until a solution is in place, let's not complain about how lame Netgear is for not having this solved sooner. I'm sure the Netgear staff is as frustrated with this situation as we are. Telling them you think their company stinks isn't going to motivate them to find a solution faster.
I appreciate Elaine's efforts to keep us posted and offer up some suggestions on possible work arounds. The more we try the work arounds the more likely we are to find something that works for us until a permanent solution is in place.
Just my $0.02.
John
- daraghfiDec 08, 2015Aspirant
Thanks, John - I respect that. Good point about not making the Netgear employees feel bad.
D
