JLEVAVASSEUR
Sep 13, 2015Tutor
NETGEAR USB Control Center utility for MAC OS X El Capitan
NETGEAR USB Control Center utility v 2.22 is not compatible with MAC OS X El Capitan, where to download or make NETGEAR USB Control Center utility with the new MAC OS X ?
- Mar 16, 2017
Hello All,
You may now download the official release of the USB Control Center Utility for MAC OS 10.11 and above from the link below.
tuckerm2
Jan 04, 2016Aspirant
- SteveBokerJan 05, 2016Aspirant
Another unsatisfied user. I replaced an Airport system with Netgear R6400 thinking it was an upgrade.
Funny data point: My HP 2025 worked just fine for the first 2 weeks I had the R6400. Everything had been set up using the Airport and I was pleasantly surprised that everything worked fine when I plugged the R6400 in. No configuration necessary. Then yesterday the printer stopped working. I ran into the same brick wall that all of you have. I deleted my printer and reacquired it using bonjour. It configures itself and looks ok, but it does not print.
I've been a computer professional for some 40 years now. I am the original author of Graphtrix from way back in 1979. I know printer drivers intimately. This is going to turn out to be a very very small fix. I'm guessing that there is some ack packet that is misconfigured. This should be a day's work or less for a competent person with access to the source code. It is clear that there is no urgency to this problem from Netgear's end. Not sure why, when such a large slice of the pie is dropping on the floor.
- jmanthonyJan 05, 2016Apprentice
I have tried to be supportive of Netgear on this issue, but I agree that an update on where they are in the process is long overdue.
Where in the heck are we on this one???
John
