JLEVAVASSEUR
Sep 13, 2015Tutor
NETGEAR USB Control Center utility for MAC OS X El Capitan
NETGEAR USB Control Center utility v 2.22 is not compatible with MAC OS X El Capitan, where to download or make NETGEAR USB Control Center utility with the new MAC OS X ?
- Mar 16, 2017
Hello All,
You may now download the official release of the USB Control Center Utility for MAC OS 10.11 and above from the link below.
LostPetrel
Feb 16, 2016Apprentice
I see this was tagged as a solution, let us be clear, THIS IS NOT A SOLUTION FOR MANY OF US!
morrissey007
Feb 16, 2016Star
I Agree 100%. this is at best a WORKAROUND. It is NOT a solution and wont be until Netgear get off their backsides and do what they should have done LAST YEAR.
- MXFeb 16, 2016Guide
Hang on morrissey007, it's not even as good as that.
My dictionary defines workaround as, "a method for overcoming a problem or limitation in a program or system"
For me the problem has not been overcome at all, thus, this is not a SOLUTION and also is not a WORKAROUND.
My System Preferences/Printers & Scanners just doesn't see my printer at all so I have no way of printing via wifi even with Bonjour
THIS IS UNACCEPTABLE AND IS NEITHER A SOLUTION NOR A WORKAROUND
MX
- StoneymaxFeb 25, 2016Aspirant
I am sharing my WNDR4500v3 router with a windows laptop and a Mac Mini running 10.11.3. Since Netgear doesn't have USB control for EC, I was using the bonjour printer and it was working but now I can see the printer when I add a printer on the Mac but when I try and print, it errors out and says that it cannot connect to the printer. I have rebooted numerous times and even waited a few days but to no avail. Anyone have any thoughts, (that can be shared here)?
