JLEVAVASSEUR
Sep 13, 2015Tutor
NETGEAR USB Control Center utility for MAC OS X El Capitan
NETGEAR USB Control Center utility v 2.22 is not compatible with MAC OS X El Capitan, where to download or make NETGEAR USB Control Center utility with the new MAC OS X ?
- Mar 16, 2017
Hello All,
You may now download the official release of the USB Control Center Utility for MAC OS 10.11 and above from the link below.
Dimyas
Dec 07, 2016Aspirant
I just installed it and now my laptop will not reboot!!!!!! Dont do it!
ElaineM
Dec 07, 2016NETGEAR Employee Retired
Kindly contact our support team.
They should be able to give you the beta.
It supports both, El Capitan and Sierra OS.
Dimyas What was the version provided to you?
- DimyasDec 07, 2016Aspirant
Forget it! You guys have DROPPED THE BALL. Why would I "try" anything else from NetGear!!!!??????
- ElaineMDec 07, 2016NETGEAR Employee Retired
Dimyas Give me a case number or your Customer ID and I will make a follow up on your case.
- CharlesinAustraDec 08, 2016Star
Just thought I might report on what happened when I sought the beta.
Only able to obtain a support phone contact number (from Australia) via a website that gives these for a large number of companies. The Netgear website seems to not publish these.
Hours (literally) spent on phone trying to get through to Support and then to get them to understand what they needed to do (just give me access to the beta). They did no know anything about this problem and the first 2 could not even locate the case number we were given by Elaine. They reminded me that my 90 days of free support had expired for my router (one of four Netgear routers I have) and one even asked if I was interested in purchasing support! Also, they were avoiding passing me on to Level 2 support even though I kept requesting this. Spoke to 3 people (plus 1 Supervisor in background) before really helpful Gokul (who knows Elaine) phoned me back and then passed request on to Level 2 Support.
Was emailed a link to an Agreement (including NDR) I had to agree to. Then sent a link to the download. This produced a .rar file (rather than using zip which is native on macs) which I had to get a program to unpack (used "The Unarchiver" from the App store).
Executed the installer, but it seemed to achieve nothing. Ran uninstaller and installer again, but no result. Notified Level 2 Support.
No problem on my system as a result. I run latest Sierra (10.12.1) on an iMac (27-inch, Late 2012).
Suspect "beta" is more like an "alpha".
