JLEVAVASSEUR
Sep 13, 2015Tutor
NETGEAR USB Control Center utility for MAC OS X El Capitan
NETGEAR USB Control Center utility v 2.22 is not compatible with MAC OS X El Capitan, where to download or make NETGEAR USB Control Center utility with the new MAC OS X ?
- Mar 16, 2017
Hello All,
You may now download the official release of the USB Control Center Utility for MAC OS 10.11 and above from the link below.
cleudio
Dec 30, 2016Guide
where is the link of this update?
ElaineM
Dec 30, 2016NETGEAR Employee Retired
cleudio Contact support and tell them the beta software for the USB Control Center Utility for your Mac computer.
- solidairsDec 31, 2016Tutor
Hello Elaine, seasons greetings. I would like to test the USB Beta software but find it impossible to make this request via your customer support. Could you please provide a link to download the required files - either here on this forum ir direct to my associated email address.
Many thanks.
- jmanthonyDec 31, 2016Apprentice
Elaine,
I think it would be very helpful for you to confirm that the technical issues Charles identified in his follow up notes have in fact been taken care of. Also, as others have noted, it would be more helpful to post a link so we can get the beta directly rather than rely on the tech support channel. I don't see what their involvement adds to the solution.
What do you think??
Thanks.
John
Hi John,
I completely agree with your comments. After such a long awaited update to the USB Control Centre it would be, at least, expected that the Beta was more readily accessible and that it was OSX friendly to unpackage and install. Having said that, after an anus horibilis it seems there may be some progress occuring.
Seasons greetings,
CT.
