IMKashif
Dec 28, 2019Aspirant
Netgear WGR614 V9 updated firmware required
Dear Members. Please help me regarding the firmware update, my router has firmware version v1.0.11_1.0.1VGUK.chk I have found a lot on but no updated firmware found. Every firmware which i got from ...
- Dec 30, 2019
Check those sites to see.
Dec 28, 2019Guru - Experienced User
1. Are you extracting the firmware prior to trying to install it? Once you download it, you need to extract the zip file before trying to upload it to the device. You can't just double click on it. If you're on windows, right click and go to extract.
2. It might be time for an upgrade. The v9 you're on was released in 2008, the original was released in 2003 when windows xp was still in use. We've advanced from wireless g---->wireless N---->wireless AC------wireless AX. its a bit dated and probably put its time in being a 11 year old device.
