rroque
Jan 26, 2021Follower
Netgear WIFI repeater(externder)
I bought a netgear ex3700 to extend my wifi signal to the first floor.
My home network is google fiber. Their wifi routers do not support wps.
So my question is how do I install the netgear extender without using wps. The wps function is there so that installers don't have to login with username and password.
1 Reply
You can use the installation assistant.
Its the 2nd video on the series.
EX3700 | AC750 WiFi Range Extender | NETGEAR Support
