jenelsebo
Apr 24, 2022Follower
Netgear wifi router not working with Spectrum motem
I played my wifi bill late, after the company had temporarily disconnected the wifi, however when they turned it back on my 3rd party, netgear router stopped working. It turns on, theres lights nex...
Apr 25, 2022Guru - Experienced User
1. what modem do you have?
2. what router do you have?
3. what firmware is on the router?
Try this.
Disconnect the coax from the modem and power it off.
Disconnect everything from the router and power it off as well
Wait a couple minutes.
connect the coax back to the modem and then power the modem on.
Wait a couple minutes for it to fully boot.
Connect the lan cable from the modem to the wan port on the router.
power it on. and give it a couple minutes.
Try setup on the router.
