juleshyp
Jan 24, 2018Aspirant
Netgear wireless adapter AC600
Purchase this adapter today. I have downloaded all the recommended software for Windows 10. I've tried the 32 version and the beta version (33). It seems impossible to contact support and I'm getti...
- Jan 24, 2018
Thank you for your reply.
In desperation, I inserted the dongle into the USB and Windows 10 installed it, without any further assistance from me.
In the end, I did not require the software at all.
It seems to be functioning well
michaelkenward
Jan 24, 2018Guru - Experienced User
AC600 is not a Netrgear modem number, but a wifi speed thing.
Is this the A6100 Wireless AC Adapter?
That's just a guess on my part, you have posted in the Wireless N Routers area of this forum, adapters are here:
WiFi Adapters - NETGEAR Communities
There is a manual and other support stuff for the A6100 at the end of this link:
>>>> A6100 | Product | Support <<<<
I have an A6100. It is important to follow the instructions as to when you have the thing plugged in.
Looks like Windows is messing you about.
- juleshypJan 24, 2018Aspirant
