ToniDB96AspirantFeb 22, 2021Netgear Wireless troubleshootingThe LED light above the wireless symbol will not light up. Tried resetting, rebooting via Ethernet cables, and it still won’t work.
3 RepliesReplies sorted by OldestplemansGuru - Experienced UserFeb 22, 2021Did you try pushing the wifi on/off button for 2 seconds on the back?R6220 | WiFi Router | NETGEAR SupportToniDB96Aspirant to plemansFeb 22, 2021I did, still no luck unfortunatelyplemansGuru - Experienced User to plemansFeb 22, 2021And you did a full factory reset? Pushing and holding reset for 7-15 seconds while the router is powered on?
