RandyBU
Jan 30, 2018Follower
Netgear Wn3000RP
I have a Wn3000rp extender that I am trying to hook up to my router. I have tried to use the WPS method but althow there is a light there is no WPS button on my router. If I go to the Website that...
- Jan 31, 2018
First of all, since you got a new gateway to match it with. You need to reset your Wn3000RP back to factory settings. To do that you need to press the pinhole with a paper clip for about 30 seconds to set it back to factory settings. As you can see on the back label of the WN3000RP there will be a login address or IP such as 192.168.2.1 or something like that. and the user and password to log into it. Once you login to it, it will start the setup. Let us know if that helps. Otherwise if this is too complicated for you, you should look for the manual online.
wcalifas831
Jan 31, 2018Prodigy
michaelkenward
Jan 31, 2018Guru - Experienced User
There is a manual for the WNR1000v3 somewhere at the end of this link:
>>>> WNR1000v3 | Product | Support | NETGEAR <<<<
