Threather's avatar
Threather
Netgear WND4300 Inconsistent pings
Model: WNDR4300 Firmware: v1.0.2.88 OS: Windows 10    I am currently running into an issue where if I connect my PC to my WNDR4300 via ethernet cable or wireless, I have major ping issues.  I am ...
  • ElaineM's avatar
    Sep 15, 2017
    Welcome to the community, Threather
    What are the devices connected to your network?
    Try to connect one by one and then do a ping test.
    This is to verify if there's a device that's causing this.
    Have you tried reinstalling the firmware? How about factory resetting the unit?
