Threather
Sep 13, 2017Aspirant
Netgear WND4300 Inconsistent pings
Model: WNDR4300 Firmware: v1.0.2.88 OS: Windows 10 I am currently running into an issue where if I connect my PC to my WNDR4300 via ethernet cable or wireless, I have major ping issues. I am ...
ElaineM
Sep 15, 2017NETGEAR Employee Retired
Welcome to the community, Threather
What are the devices connected to your network?
Try to connect one by one and then do a ping test.
This is to verify if there's a device that's causing this.
Have you tried reinstalling the firmware? How about factory resetting the unit?
Threather
Sep 29, 2017Aspirant
My apologies for the late reply, i've been constantly troubleshooting the issue and having to let it run for 3-4 days before i could confirm if it worked or not.
Only my Laptop was connected to the router, the router was not even connected to the cable modem
This occurred from multiple devices when solo connected to the router
I updated to the latest firmware, and then I re-flashed the firmware to no avail
After 7-days of testing, this has fixed the issue.
- ElaineMOct 02, 2017NETGEAR Employee Retired
Thank you for the update!
