Hank1111's avatar
Hank1111
Follower
Nov 21, 2020
NETGEAR WNDR3400 Router
I have a dell dimension 8300 computer running windows 10.  With a netgear wndr3400 router. I recently upgraded my internet speed from 100mb to 200 but am only getting 100speed. If I connect the computer directly to my modem with the ethernet cable I get the 200mb speed. I wonder if my router is the problem or the broadcom netlink (tm ) gigabit ethernet adapter in my computer. The adapter is set on auto but it looks like the most it allows is 100mb. I would appreciate any help
1 Reply
  • > [...] If I connect the computer directly to my modem with the ethernet
    > cable I get the 200mb speed. [...]
       That would seem to clear the computer (and its Ethernet interface) of
    blame.
    > [...] I wonder if my router is the problem or the broadcom netlink
    > (tm ) gigabit ethernet adapter in my computer. [...]
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the Reference Manual.  Read.  Look for
    "Technical Specifications" and "Interface Specifications".  If the
    Ethernet interfaces on your router are 10/100Mb/s, then you'll need a
    newer/better router to get speeds higher than that.
    > [...] The adapter is set on auto but it looks like the most it allows
    > is 100mb.
       "auto" means that the interfaces negotiate a best speed between
    themselves.  If one end is limited to 100Mb/s, then that's the best
    speed you'll get.
       (Note: "m" = "milli" = 1/1000.  "M" = "mega" = 1000000.)
