barsim2
Dec 12, 2022Follower
Netgear WNDR3400 V2 dashboard
Hello, Unable to get into my rourter dashbord because some time ago i changed the manufacturer credentials (admin and password) to something different that i didn't keep. Is there any way to overco...
- Dec 13, 2022
barsim2 wrote:
.... some time ago i changed the manufacturer credentials (admin and password) to something different that i didn't keep.
The only thing that you could change would have been the password. The "admin" bit is fixed.
Dec 12, 2022Guru - Experienced User
Not sure if password recovery works on that old of a device but you can try.
If not, you can always factory reset it to get back to the defaults and then just reinstall it
