dough041
Aug 07, 2016Aspirant
netgear wndr3400v2 wont let new devices on wireless anymore?
I use my router through my comcast cable router ( bridged) and it functions fine except for a while now I can't add any new devices to the access control ? It shows them under allowed devices not con...
- Aug 12, 2016
Thanks a lot for your help Elaine... Got what you said. Not sure if I'll pull the trigger to reset quite yet. Why do today what you can put off until tomorrow...hahaha
ElaineM
Aug 10, 2016NETGEAR Employee Retired
Hi dough041
Welcome to the community!
Looks like you're unable to add devices under Access Control.
Will you be able to add another device when you take one from the list?
What are the settings you have enabled on the router?
Do you have Port Forwarding, Block Sites, Block Services, USB Storage enabled?
How many devices are connected (wired and wireless)?
- dough041Aug 10, 2016Aspirant
I can access the wireless on all 7 devices ( 2 wired/6 wireless). However for the last 8 months or so when I try to let family enter their MAC address to my allowed list it won't enable them to get on the wifi such as iPhones, smart tv etc. My android phone does connect but doesn't show up on the allowed list.Am afraid to hard reset router as maybe then it will not allow me to connect any new devices including ones currently on like roku, Amazon etc...
