dough041
Aug 07, 2016Aspirant
netgear wndr3400v2 wont let new devices on wireless anymore?
I use my router through my comcast cable router ( bridged) and it functions fine except for a while now I can't add any new devices to the access control ? It shows them under allowed devices not con...
- Aug 12, 2016
Thanks a lot for your help Elaine... Got what you said. Not sure if I'll pull the trigger to reset quite yet. Why do today what you can put off until tomorrow...hahaha
ElaineM
Aug 12, 2016NETGEAR Employee Retired
You're welcome. The only way you can view the settings is if you'll take a screenshot of each page of the router.
The configuration file that you have download cannot be viewed. It contains all the settings that's currently configured on your router.
If you decided to do a reset then you can always get the settings back by using the restore feature.
dough041
Aug 12, 2016Aspirant
- ElaineMAug 12, 2016NETGEAR Employee Retired
No problem. Just let us know should you need further assistance.
