erotavlas
Sep 13, 2015Tutor
Netgear WNDR4300: configured as AP via WiFi not LAN
 Hi,  I have the Netgear WNDR4300 which is a double band WiFi router with the ability to set up two WiFi networks: one at 2.4 GHz 802.11 b/n and the other at 5 GHz 802.11 a/n. I know that I can connec...
TheEther
Sep 16, 2015Guru
Try a factory reset and see if the repeater functions reappear.
I don't have much experience with openWRT but I'm pretty sure DD-WRT can do what you originally asked for.
erotavlas
Sep 17, 2015Tutor
Hi,
factory reset did not to change anything. So I'm looking for instal openWRT firmware because with respect to DDWRT it constantly receives updates (last on this september 15.05 vs 2013 of DDWRT).
Thank you
- ElaineMSep 18, 2015NETGEAR Employee RetiredHello erotavlas, Repeating Functionality was removed in the latest firmware update due to security vulnerability. The only way to get the Repeating function back is to downgrade to the previous version. Hope this helps. - erotavlasSep 19, 2015TutorHi, thank you for your reply. I solved by installing the latest openWRT 15.05 firmware and it works like a charm. - psemmelSep 20, 2015Aspirantthis information is helpful as I also have the WNDR4300 with the latest firmware version installed on it. I have an older Netgear WNR2000 I want to use as a repeater. But...per your last posts, how do I get that openWRT 15.05 to work? I am not great with computers so any help would be much appreciated. Thanks! Peter
