erotavlas
Sep 13, 2015Tutor
Netgear WNDR4300: configured as AP via WiFi not LAN
 Hi,  I have the Netgear WNDR4300 which is a double band WiFi router with the ability to set up two WiFi networks: one at 2.4 GHz 802.11 b/n and the other at 5 GHz 802.11 a/n. I know that I can connec...
erotavlas
Sep 17, 2015Tutor
Hi,
factory reset did not to change anything. So I'm looking for instal openWRT firmware because with respect to DDWRT it constantly receives updates (last on this september 15.05 vs 2013 of DDWRT).
Thank you
ElaineM
Sep 18, 2015NETGEAR Employee Retired
Hello erotavlas,
Repeating Functionality was removed in the latest firmware update due to security vulnerability.
The only way to get the Repeating function back is to downgrade to the previous version.
Hope this helps.
- erotavlasSep 19, 2015TutorHi, thank you for your reply. I solved by installing the latest openWRT 15.05 firmware and it works like a charm. - psemmelSep 20, 2015Aspirantthis information is helpful as I also have the WNDR4300 with the latest firmware version installed on it. I have an older Netgear WNR2000 I want to use as a repeater. But...per your last posts, how do I get that openWRT 15.05 to work? I am not great with computers so any help would be much appreciated. Thanks! Peter - erotavlasSep 20, 2015TutorHi,
 the firmwares for 3700 and 4300 are both here: https://downloads.openwrt.org/chaos_calmer/15.05/ar71xx/nand/
 In particular, you have to download this https://downloads.openwrt.org/chaos_calmer/15.05/ar71xx/nand/openwrt-15.05-ar71xx-nand-wndr4300-ubi-factory.img and then you can install it from GUI by connectting to router.
 Regarding to WNR2000 http://wiki.openwrt.org/toh/netgear/wnr2000 you have to find which version do you have by taking a look at the bottom of the router and then you can download the appropriate firmware. The installation procedure is the same as WNDR4300.
