angelot
Jan 30, 2016Aspirant
Netgear WNDR4500 N900: how to timing WIFI?
I have the router in question, and I want to know if it is possible to time the switching on and off of the section WIFI. In the manual I found nothing about it. Thanks.
- Jan 30, 2016
I can't find any manual for the WNDR4500v1, but for the WNDR4500v2 and WNDR4500v3 you can schedule to disable Wireless access through ADVANCED > Advanced Setup > Wireless Settings. Note, the WNDR4500v2 manual barely mentions this feature on page 87. The WNDR4500v3 manual on page 111 is better.
TheEther
Jan 30, 2016Guru
- angelotJan 30, 2016Aspirant
Ok, thanks you very match! :)
