angelot
Jan 30, 2016Aspirant
Netgear WNDR4500 N900: how to timing WIFI?
I have the router in question, and I want to know if it is possible to time the switching on and off of the section WIFI. In the manual I found nothing about it. Thanks.
- Jan 30, 2016
I can't find any manual for the WNDR4500v1, but for the WNDR4500v2 and WNDR4500v3 you can schedule to disable Wireless access through ADVANCED > Advanced Setup > Wireless Settings. Note, the WNDR4500v2 manual barely mentions this feature on page 87. The WNDR4500v3 manual on page 111 is better.
TheEther
Jan 30, 2016Guru
angelot
Ok, thanks you very match! :)
