SentryOmega
Jan 14, 2016Aspirant
NETGEAR WNR1000v3 - public IP instead of private IP
Hello I moved to a new house and set up and internet service here. So I've had my own modem + router (WNR1000v3). The router itself works fine and providing internet. However, when I tried to...
- Retired_MemberJan 17, 2016
Retired_Member
Jan 15, 2016What is the default gateway IP address shown in your PC That should be the address used to access router. If other than 192.168.1.1 or 10.0.0.1 factory reset it.
SentryOmega
Jan 16, 2016Aspirant
It is other than the ones you mentioned.
It is in fact a public IP of my service provider (I checked with them)
How do I factory reset the router?
- SentryOmegaJan 17, 2016Aspirant
Thank you. This helped.
