mselder
Jun 12, 2017Aspirant
NETGEAR WNR2000 v4-cannot access WPS settings and cannot connect devices to wifi
My power went out briefly about 24 hours ago, and ever since, I have not been able to connect to the wireless network with any of my devices. It doesn't even show up as an available network to join. ...
- Jun 14, 2017
Ok, I give up. I am going out after work tomorrow to pick up a new router. Thanks for trying.
mselder
Jun 13, 2017Aspirant
Thank you for the response. This is what I have done already multiple times. I just tried it again now, and the same thing happens. Internet is working fine, but when I turn on the wifi, the WPS button lights up also and cannot be turned off. When I login, I am unable to deselect the WPS settings. I can see them, but they are gray and I cannot click anything. The WPS wizard is also inaccessible. My wireless network does not show up on any of my devices, thus I am unable to use wifi. Has this happened to you before?
William10a
Jun 13, 2017Master
Have you consider not using Genie to set up the router and it's setting that want to adjust?
- mselderJun 13, 2017Aspirant
Yes, I misspoke when I said Genie, I meant routerlogin.net. I did also try the Genie app from my phone, but was unable to do anything with it since I wasn't connected to my wifi. No matter what I do, the WPS remains on and I assume that is why I cannot see my wireless network.
- William10aJun 13, 2017Master
If you still wired lan access too the router you may need to reflash the router with new firmware but first have you tried a 30-30-30 reset on the router?
1 press and hold the reset button for 30 seconds with power on to the router
2 keep pressing the reset button and remove power from the router for 30 seconds while keeping the reset pushed in
3 keep pressing the reset button and reapply power to the router while pushing the reset button in for 30 seconds
This will clear any settings including the nvram of the router
Sounds like the firmware is damage some how from the event that cause the power lost.
Ok, I just tried that. Internet light stayed orange after restart so I logged into routerlogin.net for setup. Internet setup worked. I then pressed the button on the router for wifi, light came on without the WPS enabled. However, I had to re-add my network name and password. Once I did that and saved, the wifi light went out. I pressed the wifi button again and it came back on along with the WPS light again.. Any other suggestions?
