Chearful
Dec 08, 2015Aspirant
Netgear WNR2000v2 - Cannot login
Hello, I currently have a WNR2000v2 router. I need to port forward something to my PC but I cannot seem to authenticate in. You can see this in the GIF: https://gyazo.com/66de7a3d46eb225173f79ab4...
- Dec 08, 2015
Perhaps the router is not fully resetting itself.
Try to use a paper clip. If the same thing happens, it could be a hardware problem.
By the way, did you try to use a different computer and a browser?
ElaineM
Dec 08, 2015NETGEAR Employee Retired
- ChearfulDec 09, 2015Aspirant
I have tried it on Chrome and Internet Explorer on my main PC and laptop without any luck.
I will attempt to fully reset my router again but with a paper clip.
