Chearful's avatar
Chearful
Netgear WNR2000v2 - Cannot login
Hello, I currently have a WNR2000v2 router. I need to port forward something to my PC but I cannot seem to authenticate in.   You can see this in the GIF: https://gyazo.com/66de7a3d46eb225173f79ab4...
  • ElaineM's avatar
    Dec 08, 2015
    Perhaps the router is not fully resetting itself.
    Try to use a paper clip. If the same thing happens, it could be a hardware problem.
    By the way, did you try to use a different computer and a browser?
