jensixstones
Sep 12, 2017Aspirant
Netgear WNR2000v3 wifi connection failure
Netgear WNR2000v3 Router Firmware Version V1.1.2.18 I'm having trouble connecting a Kindle to my parent's wifi. I don't think it's an issue with the Kindle because it connected to my wifi, and sever...
- Sep 13, 2017
Thank you ElaineM. I set the router to open, no password required, and that didn't work. I decided to go buy a variety of wifi routers and found one that works. I'm currently replying to this thread from a wifi connected device.
Thanks for your help!
ElaineM
Sep 13, 2017NETGEAR Employee Retired
Welcome to the community, jensixstones
Try to disable any wireless encryption and connect to the wireless network.
If you were able to connect I suggest that you try to enable WPA2-PSK [AES] and see if you will be able to connect.
jensixstones
Sep 13, 2017Aspirant
- ElaineMSep 13, 2017NETGEAR Employee Retired
Thank you for the update.
Enjoy!
