jensixstones's avatar
jensixstones
Netgear WNR2000v3 wifi connection failure
Netgear WNR2000v3 Router Firmware Version V1.1.2.18 I'm having trouble connecting a Kindle to my parent's wifi. I don't think it's an issue with the Kindle because it connected to my wifi, and sever...
  • jensixstones's avatar
    jensixstones
    Sep 13, 2017
    Thank you ElaineM. I set the router to open, no password required, and that didn't work. I decided to go buy a variety of wifi routers and found one that works. I'm currently replying to this thread from a wifi connected device.
    Thanks for your help!
